Installed a high power LED beacon light on the bottom fuselage. It looks pretty cool I think and helps others recognising me. It flashes and has a greart intensity. After the second look at it, I decided to recess the white part fully into the fuselage. That should look a bit neater and sure produces less parasite drag. Therefore I will need to construced a little light bracket inside.
